i think i have too much oil
Old Sep 3, 2005 | 07:01 PM
ecksman's Avatar
Default i think i have too much oil
i changed mt oil and when i checked the dipstick it said i had too much, like the oil went on to the orange part of the dipstick, but i know i put 5.5 quarts, i still have the 5.5 empty bottles and drain pan full of the old oil
Old Sep 3, 2005 | 08:03 PM
beefski's Avatar
Default RE: i think i have too much oil
did u fill the filter b4 putting on?
if not, that will take at least a half qt.
how level is the spot where u r checking?
Old Sep 3, 2005 | 10:29 PM
headshok2002's Avatar
Jeebus... my car takes like 4.5 quarts (2000 1.8T) -- and I'm using the higher capacity filters.
Be sure to drain it, if you are checking on level ground, and have started the car to fill the filter... too much oil will, among other things, damage your catalytic converter.
Hmm, well, "will" damage should read "may" damage.
Old Sep 3, 2005 | 11:54 PM
Silver98A4's Avatar
thats wierd...i have a 98 A4....i changed filters everything correctly...put in 5.5 quarts like the manual says...and it wasnt enough...i checked the oil level about a week after doing it (only driving the car a very very like 30 second trip in between...cuz its not registered yet) and it was low....i had to put in the other.5 quart and now it seems fine....no leak or aynthin though
Old Sep 4, 2005 | 10:59 PM
2.8 or 1.8? Hmm.
Old Sep 4, 2005 | 11:10 PM
audiboy1618's Avatar
yeah really, 1.8t or 2.8, if you have that much oil in there, you have a problem
Old Sep 5, 2005 | 01:23 AM
david9999's Avatar
What engine and what TRANSMISSION?
Is the first time you changed the oil in your car yourself?
Is your car a tiptronic? If so, common noob mistake is to drain the transmission rather than the oil pan.
My 1.8T takes about 4.5 quarts with the larger filter.
Get a siphon and pull out oil from the dipstick. If you have to pull out 2 or more quarts and if you have a tiptronic, you have to wonder.....
Old Sep 5, 2005 | 01:25 AM
ecksman's Avatar
about the 10th oil chamge i've done on this car myself, pretty handy mechanically, just lazy
Old Sep 5, 2005 | 01:26 AM
ecksman's Avatar
almost forgot 2.8 manual fwd
