ignition problem
turn key with no response only a few clicking..not battery cant find an ignition relay ... where would that be and its probabbly a starter? </P> </P> am i right?</P> |
ignition problem
Hey, You sure its not the battery. It may read 12 volts, only it could have a bad cell? Just a thought, I work at a dealership, happens all day long. All Acc. in vehicle will work, and seem to have plenty of power. These vehicles have smart systems,clicking is most likley caused bya bad battery, system is sensing battery voltage too low when starter is engauged.... have never seen an ignitionmodule go bad, with that result. Only way to check it is by performing a batteryload test. I would start there. Good luck.</P><edited><editID>taudiguy</editID><editDate>37980.9072106481</editDate></edited> |
ignition problem
If you are hearing a repeated clicking sound - I will say 100% its a dead battery.
