Indicator light That I've never seen???
Well I haven't posted on here for a whilebecause I haven't had a lot of problems, I just got my timing belt changed, and whileI was at it had the water pump, thermostat, and some of the other major belts changed, along with that I got a tune up and oil change, I also had to change to of the coil packs, because they were causing the car to not start! After all of that the car ran great, I noticed that the "Service Oil" light was flashing every time I started the car and thought that it was because the mechanics just forgot to reset it, but just yesturday the light changed to "Service INSP," and I have no idea what this is, it's no where in the manual, and I was hoping one of you guys could help out?
ln1, ln2, "service oil" and "service inspection" are all pre-programmed messages that automatically turn on at certain mileage intervals. it's only on because your mechanic didn't reset it, nothing's wrong though
yea you can do it youre self try a search i know its been talked about.
found it
https://www.audiforums.com/m_412772/tm.htm
found it
