Injectors
Old May 8, 2005 | 08:51 PM
Peteman187's Avatar
Default Injectors
Can anyone lead me to a site that explains injectors. Can someone (Ritt??) tell me about prices, sizes, gains, when to upgrade, benefits?? Im really quite uninformed and a did a couple searches but not alot of luck. Thanks...
[IMG]local://upfiles/5642/B746A1CB70A74C288AECC0A5C46C9E4C.jpg[/IMG]
Old May 8, 2005 | 09:04 PM
GregaXX's Avatar
Default RE: Injectors
Ask here and tell them what upgrade u have and they will help you.
http://www.ctsturbo.com/injectors.php
Old May 9, 2005 | 01:15 AM
audihere's Avatar
Banned
317 or 384 are used for the k04 upgrade. 440cc or 475 are used for the gt28rs upgrade. and im guessing 675 or higher is used for the gt3071rs upgrade.
Old May 9, 2005 | 02:05 AM
trailboss's Avatar
Well if you have giac software for a N-DBW A4 with a k04 you would use 310cc injectors and fpr set at 3 bar or 2.7 if you got an adjustable fpr assuming you have the pc-16 giac file. Those injectors are called bosch red tops, 310cc, bosch part# 0280150945 or ford notorsports part # F1SE-E1A. Are you on the stock k03 or what kind of turbo do you have, that will help alot.
Old May 9, 2005 | 02:32 PM
Peteman187's Avatar
Stock K03. APR 1 Bar. So im guessing there would be no benefit to me upgrading them?
Old May 9, 2005 | 08:26 PM
Jeff's Avatar
Zombie Defense Force
i used 550cc injectors with a T3/T4 turbo
Old May 9, 2005 | 08:46 PM
TomRitt's Avatar
No benefit for you no. Injector sizing depends on your progamming. You can look at the duty cycle with the vag-com and see if the injectors are being maxed out (95-100%). Also look at maf values and see if thats maxed out (I cant remember max value but i think maybe 186, or 286?) If either of those are maxed out, which the wont be on ur set-up, it would be benifitial to upgrade injectors and maf. You have to keep the scale the same, for example if you increase injector volume by 50%, you will need to increase the suraface area of the maf by the same amount, 50%. This keeps the ecu happy
Old May 10, 2005 | 01:56 AM
Peteman187's Avatar
Thanks dude thanks alot. Wow your buddys rex has huge inectors. What turbo is he running again?
Old May 10, 2005 | 09:34 AM
TomRitt's Avatar
Yea he is putting smaller injectors in on Thursday, hes going to dual stage 660cc's. Hes running a Deadbolt 18g
george1546
May 5, 2013 06:57 AM
xxipsxx
Dec 11, 2010 03:13 PM
TeeterTawter
May 18, 2008 01:01 PM
pa4ul
May 3, 2008 02:43 PM
MC Hammered
Feb 4, 2008 12:06 AM
