Inner C/V joint & boot install
Old Apr 7, 2005 | 02:20 AM
BlueLord's Avatar
Default Inner C/V joint & boot install
2001 1.8T Quattro Manual
Does anybody haev a write-up on the inner, or outer for that matter, c/v joint and boot install. I did a search but came up with no install write-up.
Also is there a good place to purchase these from. I saw that ECStuning has the rear inners but I didn't see the fronts.
Any Info would be helpful, just bought the car two months ago and they were\are leaking (well the pass front and drivers rear were\are leaking transmission fluid. I one of the boots has a tear in it.
Thanks,
Pete
Old Apr 7, 2005 | 02:46 AM
BFlan2001's Avatar
Default RE: Inner C/V joint & boot install
here's a writeup on the boots....no joints though, sorry
Old Apr 7, 2005 | 02:57 PM
BlueLord's Avatar
bentframe - Thank you very much. I think that that write up covers the C/V joint pretty well. It focuses on the boot but gets me close(r). Seems pretty easy compared to what I was thinking. The qoute I got was pretty pricey from the stealership. I will have to look into doing this my self since I really should do all 4 while I'm under there. Maybe the control arms as well.
Also, if anybody knows where I can get the joint and boots cheap please let me know.
Thanks,
Pete
Old Apr 7, 2005 | 03:04 PM
BlueLord's Avatar
Oh yeah one other question:
How would I know if the C/V joints are actually bad? I know that they are leaking and need a new gasket/seal but how would one know if they were actually bad. I think since they will be off I will replace them anyway but how do you tell?
Thanks Again,
Pete
Old Apr 7, 2005 | 04:51 PM
BFlan2001's Avatar
ecstuning sells a boot kit, or you can buy the complete axle....don't know if they sell just the joints though...you'd have to have a mechanic tell you if your joints are bad...it may just be the boots. they'll make a loud clicking sound when the wheel is turned and the joints have a load on them...
viperpit07
Sep 8, 2011 10:37 PM
captcaos2002
Jul 7, 2010 02:40 PM
Dragon59
Apr 4, 2009 02:48 PM
diablo9861
May 31, 2008 03:06 PM
Mya4T
Oct 26, 2007 07:34 PM
