is installing a DV hard?
Old Jun 29, 2007 | 01:58 PM
fumoazul99's Avatar
Default is installing a DV hard?
I know that there is tuturials out there for it... but me being a newb in installing or replacing car parts, im wondering if i could do it myself...
I own a 1998 A4 1.8T....
Did you guys find it hard to do it?
Should i just bring it to my tuner and have him charge me all the wonderfull labor?
Thankx for any advice
Old Jun 29, 2007 | 02:00 PM
sean1.8t's Avatar
Default RE: is installing a DV hard?
extremely easy. just 3 hoses conect it. access it from underneath the car. right under the intake
Old Jun 29, 2007 | 02:15 PM
onepoint8tee's Avatar
Dont forget to jack up the passanger side a little, that will help.
Old Jun 29, 2007 | 02:20 PM
less_of_me's Avatar
Have some metal snips handy.....or a dremel. Those one time hose clamps are a pain. If you don't have either of those...you can use a screw driver to prythem open.
Old Jun 29, 2007 | 02:25 PM
akielb's Avatar
and have small clamps ready for the install since the other one's are not reusable - check the hose(vac line) that goes from the intake manifold to the DV, make sure its not old, broken, and cracked.
Old Jun 29, 2007 | 02:33 PM
You can use a zip tie in place of the small one time use crimp clamp for the small vac line on top of the DV. +1 for tin snips to get the old one off. Probably a good idea to replace the vac line since youre in there.
Old Jun 29, 2007 | 02:45 PM
18tq_redflag's Avatar
It's easyer to install then to take off because of the clamps. Just remember to look at it and remember which end goes where. Where eye protection and use a jack stand. Maybe have a flash light handy just to look around before you do anything.
Old Jun 29, 2007 | 03:33 PM
Lelix's Avatar
once you get the clamps off its cake
Old Jun 29, 2007 | 04:28 PM
smokeU's Avatar
install it backwards...
Old Jun 29, 2007 | 07:00 PM
malvagna's Avatar
is it the same basic install for a b7?
