jumpy accelerate???
Old May 31, 2006 | 02:18 PM
rnbguy's Avatar
Default jumpy accelerate???
hi ive recently chipped my car to a 1bar neuspeed chip, and its been fine, however ive noticed under heavy acceleration in gear 2 and 3 the car will stutter like it cant breathe???
no error codes at all???
anytips?
Old May 31, 2006 | 02:20 PM
clconversion's Avatar
Default RE: jumpy accelerate???
change your dverter valve that is the best place to start
Old May 31, 2006 | 02:33 PM
rnbguy's Avatar
dv and n75 recently just replaced, u think maybe fuel pressure regulator? where is that neway?
Old May 31, 2006 | 02:36 PM
aRIf's Avatar
I think you have to have new fpr with neuspeed chip. Check their website it tells you what you need with the chip
Old May 31, 2006 | 02:42 PM
rnbguy's Avatar
yeah u do, but the guy i bought it off said i dont need one ???
is there anyway to test it using vag????
also is there neway to test dv using vag?
Old May 31, 2006 | 02:46 PM
the fuel pressure regulator is in the fuel rail not 100% sure on this but I think the nonDBW's use a 3 bar and the DBW's use a 4 bra switch it up and see what happens
Old May 31, 2006 | 02:47 PM
rnbguy's Avatar
okay will do, however for now to kill time any tests i can perform using vag? on dv or fpr?
Old May 31, 2006 | 03:33 PM
north5995's Avatar
Get a boost guage...
Are you getting jerkyness? Change the spring in your DV.
Old May 31, 2006 | 03:46 PM
rnbguy's Avatar
yeah the spring was just changed recently, the dv came of my mates TT...
but now i got a huge FN problem!!!!
just before i got home tonight, (australia time) the oil light came one, i had the car on for about 5 minutes to do a u turn and park it outside my house , i checked the oil and not one single drop of oil is in the car, not even 1mm, mechanic has told me that the rocket head cover needs replacing, and also some cover down the bottom of the engine too, but does it make sense, oil was on half 2 weeks ago...?
i checked coolant and its clean, so no mixing there!!!
can that 5 minutes i had the car on without oil have destroyed anything?
also could this be related too the jerkiness i was getting before?
Old May 31, 2006 | 04:51 PM
north5995's Avatar
Yeah thats definately not good. Your oil lubricates all the metal components in the engine. Hopefully you didn't fry anything. You probably need to replace the head and oil pan gaskets, or maybe you do have cracks or something. Listen to your mechanic if you trust him.
