Just logged my CAPS time.....
Old May 29, 2006 | 04:29 PM
quattrosedan's Avatar
Default Just logged my CAPS time.....
So I finally got around to logggin my caps time....and I am somewhat disappointed......only a 6.1.....but I guess I shouldn't be too disappointed, it was 90 degrees when I did it yesterday. And the only mods I have are:
ATP Elim GTRS
ATP 3" INLET to stock airbox
Custom 3" mandrel bent exhaust
still have stock cat, and stock smic
and I have my boost line from the turbo running straight to the wastegate, so I am only running ~14psi.
I just wanted to see what any of you guys have gotten, and how it compares.
Old May 29, 2006 | 06:33 PM
north5995's Avatar
Default RE: Just logged my CAPS time.....
You are only running 14psi on GTRS? I don't think thats right.
Old May 30, 2006 | 02:13 PM
aRIf's Avatar
-boost is low, you need mbc
-you deff. need fmic. summer is here, your oil/coolant will boil.
-6.1 is not bad for 14psi, I think.
Old May 30, 2006 | 06:26 PM
How could that not be right? If there is nothing to delay the opening of the wastegate, you can only run the amount of boost that your wastegate is set for............so that is all I am running currently. With the n75 hooked up, I am running closer to 23 psi...but I don't have a fmic, so it is basically pointless.....with the temps already in the 90's.
Oh, forgot to mention, that time was with me (200lbs) and a passenger(220lbs).
So I figure, by myself in much better weather (~ 50 degrees like most people have done theirs), then I will be in the mid to high 5's. Then once I get the cat delete pipe and a fmic, I should maybe break into the 4's, but most likely just low 5's.
kiwiaudi
Jul 23, 2013 08:06 PM
Bigdog7373
Jul 25, 2012 11:40 AM
02AvantImola
May 17, 2009 03:28 PM
drumdork03
Feb 20, 2008 08:09 PM
