It just wouldn't work!
Old Sep 2, 2006 | 05:30 AM
auDi1.8TQ's Avatar
Default It just wouldn't work!
Hey Guys! I have a 99.5 Audi A4 1.8T Quattro and I need to fix this problem as soon as possible. The issue is that my power door locks just doesn't work at all. I check the fuses and all of them are just fine, just wondering what else can I check beside the code reader(because I'm going to use it tomorrow). I have to lock everything manually from the inside to make shure no ones steal my Sick B5 LOL. Also, I just install an Alpine amp a couple of days ago, do you think when i did the wiring, I screwed up one of the wires or something? or maybe something else.
Any Advice is appreciated! Thanks for taking the time to read!
Old Sep 2, 2006 | 06:17 AM
BaconBait's Avatar
Default RE: It just wouldn't work!
The door locks are operated by a vacuum pump in the trunk. Poke around where your amp is installed and make sure you didn't accidently disconnect any wires.
Old Sep 2, 2006 | 03:48 PM
auDi1.8TQ's Avatar
Can you please tell me where the actually check? I mounted the amp on the right rear passenger seat(bolted on back) with the extra wiring under the rear seats. I just wanna make shure what i need to look for. Pics? or what color wires is it? or where is it usually located? So i can see if its actually the wire unplug.
THANKS!!!
Old Sep 3, 2006 | 06:00 PM
auDi1.8TQ's Avatar
any thing please?
Old Sep 3, 2006 | 06:53 PM
kovachian's Avatar
Member
It's in the right rear of your trunk underneath the trim.
Old Sep 4, 2006 | 08:32 PM
auDi1.8TQ's Avatar
What does it look like? I see a couple of things there but unsure of what they are....can you please be more specific or show more pics....I REALLY appreciate your responses....i know im stupid
Old Sep 4, 2006 | 10:51 PM
david9999's Avatar
Find someone with a real VAGCOM and check for codes in the electric locking system.
1 - Vacuum line
2 - Right-front door lock actuator
Removing and installing page 57-12
3 - Vacuum line connectors
Disengage harness connectors page 57-42
Additional vacuum line connectors are located at bottom of A-pillar and in boot at B-pillar
4 - Right-rear door lock actuator
Removing and installing page 58-14
5 - Fuel filler flap lock actuator
Removing and installing page 57-46
6 - Central locking system pump
Removing and installing page 57-49
7 - Distribution box
Connected with all other wires excluding wire for rear lid
8 - Left-front door lock actuator
Removing and installing same as for right door
9 - Rear lid lock actuator
Removing and installing page 57-47
10 - Left-rear door lock actuator
Central locking system pump , removing and installing
The pump for the central locking system is located in the right-rear of the luggage compartment under the luggage compartment trim.
- Fold back luggage compartment trim and remove insulation -3- with pump for central locking system -1-.
- Disengage connecting line -2-.
[IMG]local://upfiles/1947/0026340486D341DB896E07556731CFE3.gif[/IMG]
[IMG]local://upfiles/1947/EDCE5755C0C04EBD901B9F9A6979A393.gif[/IMG]
Old Sep 5, 2006 | 12:54 AM
auDi1.8TQ's Avatar
THANKS ALOT David9999 and all the ppl who respond!!!! Your always helping people here...I think this will diffently help me out! I was just wondering, is this a common problems for a4?
Old Jul 24, 2007 | 02:30 PM
bluegrasserNC's Avatar
DAVID...where did you find this diagram and layout of door lock routing?
Old Jul 24, 2007 | 03:26 PM
EliteTuning1's Avatar
im guessing he has a bentley or somekind of manual were he got the pics ^
bradtyler02
Mar 25, 2014 09:29 AM
nm3210
Jan 6, 2012 12:22 AM
cclazer
Dec 24, 2007 12:00 AM
miabhai_freaked
Mar 27, 2006 08:44 PM
flyboy
Jul 24, 2005 05:18 AM
