K04 upgrade
thats it. it wont run as good as it can but you can technically do it. you can go two ways with the k04. the regular file or the aggressive file. both are from GIAC. with the regular file you will just need the k04, software, 5 bar FPR (not totally necessary but recommended), and dv. with the aggressive file (used to be the hammer file but that got replaced by some new one) you will need the k04, sofware, bigger injectors, adjustable FPR, FMIC, exhaust, and dv (new clutch wouldn't hurt either). regular k04 you will boost around 14 psi and make ~220hp. with the aggressive file you will be boosting 24-28psi and making around 250hp and 300 ft lbs of tq. add water.meth injection and it'll put out even better numbers.
