Key locked in ignition
Old Jul 22, 2006 | 08:15 PM
ejc317's Avatar
Default Key locked in ignition
I put key in - i tonly turns 1/5 of the way and won't go ....
i finally decide to risk it and turned it really hard and it finally starts - then its fine after that
is there any problem i should be concerned with
Old Jul 22, 2006 | 08:28 PM
Dj Spiel's Avatar
Default RE: Key locked in ignition
when you put your key in try jugglign the steering wheel a bit.
Old Jul 22, 2006 | 10:35 PM
ejc317's Avatar
wel the 2nd i forced the key the steering wheel spun a bit
Old Jul 23, 2006 | 10:43 AM
david9999's Avatar
Sometimes the steering wheel lock puts pressure on the ignition. Turn the wheel at bit and with the wheel held there try the ignition again. This usually works.
The other cause of this is a worn ignition lock or worn key, in which case moving the steering wheel will not solve the problem.
Laurel
Sep 6, 2011 05:07 PM
mack010s4
Nov 30, 2010 10:07 PM
Audi858
Mar 27, 2008 03:55 PM
Sichko
Jan 28, 2006 12:33 AM
Mikem
Jun 6, 2005 12:46 PM
