ko3 boost
Old Nov 3, 2005 | 02:10 AM
Dstranks's Avatar
Default ko3 boost
I was wondering what the highest amount of psi the ko3 can handle putting out. I have a 2000 audi a4 1.8tQ 5spd, borla cat-back exhaust, 3 inch inlet pipe, turboxs bypass valve k and n drop in filter and turbo timer and an apr chip. I am interested in turning my boost up even more than it has gone up from the chip but I wasnt sure where my limit with it was. I am very skeptical of pushing it past 18psi.
Old Nov 3, 2005 | 02:15 AM
PandaXpress's Avatar
Default RE: ko3 boost
i kno some people pusing over 22 psi on their B6s though
Old Nov 3, 2005 | 02:16 AM
trailboss's Avatar
You can set a mbc up to 20psi, kinda pointless and the fact that that you won't get the extra fuel needed for that boost amount since your chipped. Do you have a boost gauge? If so, your chipped and you notice how the boost fades past 5k rpms. It will be worse if you up the boost more.
Old Nov 3, 2005 | 02:25 AM
Yuikio's Avatar
18psi is a good cap. Any more than that, and that little K03 is spinning too fast to make meaningful amounts of boost.
Old Nov 3, 2005 | 03:16 AM
Slowb5's Avatar
past 18 psi, i consider the ko3 a grenade.
Old Nov 3, 2005 | 08:03 PM
audiboy1618's Avatar
Naah, high oct and spiking to 22psi would be fine. Wouldnt ran it alot though. 24psi took care of my ko4 fast.
Old Nov 3, 2005 | 08:06 PM
Yuikio's Avatar
Well, yeah, that much boost wouldn't really explode it, but 20psi is in the realm of uselessness for that little turbo. It can't flow that much air.
Old Nov 3, 2005 | 08:33 PM
petermcA4's Avatar
I'd say 14psi. This would keep it reliable
I've herd of the K03 shitting itself with more boost
Old Nov 3, 2005 | 11:05 PM
Thats boost your actaully holding. You can boost/spike up alot higher.
Old Nov 4, 2005 | 12:32 AM
Yuikio's Avatar
^^^Yeah. You can spike 18psi all day. To hold 18psi would mean you'd be spiking at like 22-23, which is bad for your fist-sized "turbo."
Spiking at 14psi would be super weaksauce. Don't be a *****. My car has spiked 17-18 and held 15 for 100,000 miles.
