ko4 question
Old Feb 6, 2006 | 02:17 AM
audiboy1618's Avatar
Default RE: ko4 question
Your exactly right, there larger and flow more only because the walls are thinner, making the flow rate higher. The b6 guys tried to run them and it wasnt good at all. Dave at Ecode tried to tune for them.
Old Feb 6, 2006 | 02:21 AM
tip5's Avatar
ive never heard of reliability issues with them i have several people running them and running 23lbs steady for about 6 months now and no problems engine or turbo wise.
Old Feb 6, 2006 | 02:25 AM
Hey sweet, bolt it up and see what happens. Just have cash to fix, Ask around any forum thats been around for a while and see what they say about a e05. Hope it all works out for ya. That turbo can flow 300hp, just not reliable.
Old Feb 6, 2006 | 11:07 AM
germancarmaniac's Avatar
its a 99.5. And yes, i do want to go with a k04 but thanks for the suggestion tip5. Now where can i get one and how much is the j31 file. Also i have a stage 1 southbend clutch, will this hold it?
Old Feb 6, 2006 | 09:38 PM
Slowb5's Avatar
mr. germancarmaniac, you will want the j31 file if you are newre than 99.5 ...but if you are 99.5 and below, you want the pc-16 file. the ko4 will fit the stock manifold, and ive seen 260 hp and 300 ft lb. get a fmic, injectors, fpr, and a nice free flowing exhaust and you should see some good numbers.
Old Feb 6, 2006 | 09:43 PM
thanks b5, now where can i get a good price on all of this stuff. And would the cheaper ebay fmic work for my purpose?
ps how much is the j31 file? giac right?
Old Feb 6, 2006 | 11:49 PM
a4's Avatar
a4
www.awe-tuning.com
Has a lot of good stuff, check it out.
Old Feb 7, 2006 | 08:16 AM
  #18
david9999's Avatar
Do not buy an Ebay FMIC. You will spend hundreds trying to fabricate lines to and from the FMIC.
Old Feb 7, 2006 | 11:47 AM
  #19
Slowb5's Avatar
ORIGINAL: david9999
um...ill take a picture of mine...doesnt look half bad, but ill be upgrading the core.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
