koni coilovers rebound setting
I was wondering what rebound setting people are using for them...also anyone have rubbing problems? at what hieghts?
RE: koni coilovers rebound setting
That is what I just order for my car, I will let you know what happens but I'm still waiting for them,
I think with rubbing it depends on what wheels you have on. |
If you lower it too much there will be running but if you roll your fenders you should be able to clear easily, 2 inch's lower is going to probably rub something
Im running 18x8 et38 and 225/40 tires...i want to be around 25.5 from ground to fender
Got mine on 80% up front, and the rear and 95%. I am also 24.5" i think, the last time i checked, with 18x8 with 225s all the way around.
^^^ Any rubbing problems?
well I just got the coilovers in yesterday and I am not that happy with them,
first all the paperworks that come with then are in german. second, I had to look up all the info on the internet on how everything works. third, for me to adjust the damper I have to removed then from the car everytime. I hope when I install them that I will be happy with then, I will be taking a guessing on what to set the dampen at, at least I can adjust the height after I install them. |
