Koni lower before rims ?
Old Jul 31, 2005 | 04:06 AM
ExpLlclT's Avatar
Default Koni lower before rims ?
1998 2.8 quattro B5 V6 <<<<< the car referd to as "it"
my dad thinks you need to get smaller tires or something before i lower my B5 with basic Koni coilovers ?
someone please rationalise this, so that i can lower it with the stock rims and tires. : /
Old Jul 31, 2005 | 04:09 AM
flyboy's Avatar
Default RE: Koni lower before rims ?
drop it. It looks like mine now and thats not good. Off roader from the factory. oh and if he askes. when you get bigger rims the outside diameter of the tire should stay the same so it wouldn't matter.
Old Jul 31, 2005 | 04:21 AM
trailboss's Avatar
Get the suspension first. I have the koni coilovers as well and i did suspension first. Definately do suspension first, you do not need lower profile tires to work, thats not a factor at all. Like flyboy said, when you get bigger wheels you get lower profile tires to keep the outside diameter of the tire the same as it was. When i put the coilovers on i had about a half a finger gap up front and my wheels were pretty much tucked and i didn't rub at all. I may have been lucky but i didn't care i just put the coilovers on and messed with the height later because i ended up getting wheels a week later.
Old Jul 31, 2005 | 04:24 AM
Beaner's Avatar
I just got eibach pro springs installed the other day..im gonna post pics as soon as i take pics
Old Jul 31, 2005 | 05:14 AM
headshok2002's Avatar
I have my new wheels... and I wont put them on my car until it's lowered :P
Old Jul 31, 2005 | 10:06 PM
Yuikio's Avatar
If you're getting coilovers, you don't need to get lower profile tires. You can adjust them to the height you want. If you get new wheels that are a larger diameter, then you need to get tires that are correspondingly smaller. ie you have 205/55-16s, if you got 17s in the same width, you would buy 205/45-17 tires.
So no, you don't need new tires to run the car lower. It's high from the factory, you have plenty of clearance to lower it over stock wheels.
Old Aug 1, 2005 | 02:50 AM
apg96's Avatar
go with what ever u wnat more first. I am doing my wheels again before i lower it. Get a rear sway bar too.
Old Aug 2, 2005 | 01:17 AM
ExpLlclT's Avatar
what will the rear sway do for it ? i thought i had one i need to check cuz i no ones in the front end, and r u talkin bout after market ?
Old Aug 2, 2005 | 01:40 AM
lidonnit's Avatar
Sprins & suspension first my son.
Old Aug 2, 2005 | 04:19 AM
apg96's Avatar
sway bars come on all cars but an after marlkert one will be stiffer and help ur handling alot. BUt do ur suspension first.
reed1099
13
Sep 18, 2009 10:26 PM
SMoLiK
Jan 30, 2007 10:34 PM
Mike@PureMS
Jan 24, 2007 02:37 PM
m5racer
Nov 29, 2006 06:06 AM
YFZFourFifty
Jul 28, 2005 03:51 PM
