Labree HFC Question
Old Nov 20, 2006 | 02:26 PM
futebol3's Avatar
Default Labree HFC Question
My Cat recently blew off my turbo at the turbo manifold and I just ordered a Labree HFC to replace the sorry Cats we get stock. They said it will be about 2 weeks, so thats 2 weeks I dont have my car...(bummer)...
Does anyone have experience with them? I've seen a lot of posts about them, but they all seemed pretty old and wanted some fresh input.
Also, does anyone know if these HFC's have the plugs for our O2 sensors? If not, what did you all do about your O2 sensors?
I know this is only a short term fix, but what are your thoughts on temporarily welding the OEM cat onto the turbo manifold so I can at least drive around, if only slowly?? A mechanic offered this as a temp. solution, but I'm skeptical...
Thanks
JB
--Current--
99.5 A4 1.8T Q-Tip
Borla Cat-Back
H&R Race Springs
Bilstein Grooved
--Upcoming--
Bailey DV
GIAC
Tint
Old Nov 20, 2006 | 03:06 PM
Lazer Viking's Avatar
Default RE: Labree HFC Question
well if you need you car, why not take your old cat down to a muffler shop, get them to cut the flanges off of it and make up a pipe to put in there temporarily (test pipe)
Old Nov 20, 2006 | 04:22 PM
ProOnThaSnow's Avatar
Because federal EPA regulations clearly state that it is ILLEGAL in any state for a shop to remove a catalytic converter. It is a huge fine, and could lead to the shut-down of a business.
Now, if they were to make a bolt-in test-pipe for you, for "off-road use only", and give it to you, without installing it on your car, whatever you do after you leave the shop is your business and responsibility. This saturday I am having the shop make mine "for off-road use only", and have them leave the stock cats on it, so when I get home, I can put the test pipes on. Then comes time to trick the O2 sensor....
Old Nov 20, 2006 | 05:10 PM
thats what i was getting at...i was assuming it was already off the car
Old Nov 20, 2006 | 05:30 PM
futebol3's Avatar
I still have the cat attached (at least to my borla), as of now. Im trying to figure out what to do with that d@mn thing.
Is it really that common to have these cat's go bad with a new exhaust on it?
I guess my options are: test pipe or rental car / bumming rides until the HFC gets in...
Thanks for the input.
Oh, and if I do this myself, it will cost maybe ~$300. The dealer said it would be ~1350 if they did it. AHA..crazy b@stards...
Old Nov 20, 2006 | 06:14 PM
Gotcha, My bad.... I was assuming it was still on the car, obviously.
chowmouse
Jul 1, 2011 10:04 AM
nova_ss672001
Jan 12, 2009 04:20 PM
asurugger
Mar 8, 2008 04:38 PM
futebol3
Nov 19, 2006 05:02 PM
Ports6689
May 9, 2006 12:47 PM
