Lots of smoke. Acts like the pedals stickin. Revs and
If you have constant misfires you wont even get a good chance to make it into boost. Change the plugs if you dont know when/if theyve beenreplaced. If that doesnt help, swap cyl 3 and 4 coil packs with 1 and 2. Check for codes. If the misfire is on 1 and 2 now, youll know its a couple bad coil packs. Im wondering about the N75 valve/or lack of one though. If its not plugged in, or if it is non existant under the hood, Id find out what is controlling your boost (or not controlling it.) If you want any more help on that youre gunna have to post a pic of what your engine bay looks like in this area: (youll have to remove the intake ducting (2 pieces) youll need a phillips head screw driver and about 45 seconds to do it.)
How long have you owned this car and how long has this problem been going on???
ORIGINAL: onepoint8tee
Thats my pic from when I was doing a boost leak test.Notice the cork? I was showing him a pic of the part of his engine bay he needs to show us.
find the wastegate on the turbo or find the turbo brass nipple. there should be a vac line attached to both of them. follow those vac lines and it will take you to what ever is controlling you boost, n75, mbc, or ebc. you gotta have something
Ok I have pics now of the turbo area with the intake removed. I dont know why but there was like oil puddling in the turbo inlet. Also I took a picture with the head off and it looks like someone took a crap in my engine. Also there was alot of carbon buildup on the plugs.
[IMG]local://upfiles/36255/C44BAF18BCD34806938474D1A9FF0057.jpg[/IMG]
[IMG]local://upfiles/36255/5088EF24BF37427BBD6967154819E41D.jpg[/IMG]
[IMG]local://upfiles/36255/B22BC91790C445D0BE590B84EEC102ED.jpg[/IMG]
[IMG]local://upfiles/36255/77AF23C76B054FBCAF2850BEB776E004.jpg[/IMG]
[IMG]local://upfiles/36255/D757AF852325428D8E6522041B5C58E6.jpg[/IMG]
More Pictures
[IMG]local://upfiles/36255/BB5DE418AD0D4E299C42BD6BA8D072DB.jpg[/IMG]
[IMG]local://upfiles/36255/7490FD8849F84649870F9C24FA139DC3.jpg[/IMG]
[IMG]local://upfiles/36255/0A6B4A164E6B4277A2443CFF0A7DDA5D.jpg[/IMG]
