Low oil pressure
Old Jan 21, 2007 | 05:56 PM
WoodyS's Avatar
Default Low oil pressure
The low oil pressure light in my daughter's 2002 A4 3.0 Quattro (46K miles) came on yesterday. The light was intermittent (on & off) so she drove it home where it is now in her garage. Of course, the 4 hear warranty expired last June.
Any ideas what might cause this problem? Is it a common problem? What is the fix?
Old Jan 21, 2007 | 06:08 PM
onepoint8tee's Avatar
Default RE: Low oil pressure
Check oil level?
Old Jan 21, 2007 | 10:35 PM
david9999's Avatar
First thing to check is the oil level. If it is OK, it could either be the oil pressure sender, or a failing oil pump. Unusual for the pump to fail on a 3.0.
If the oil is OK, have it flatbedded to a garage that works with VW or Audis. If you feel lucky, you can carefully drive it to a garage. If the oil pressure light starts flashing, shut the car down immediately and have it towed.
Old Jan 22, 2007 | 12:48 AM
WoodyS's Avatar
The first thing I checked was the oil level... it is up to the top of the dipstick. Today, I replaced the oil pressure switch. We drove the car for about 20 minutes with no light at all. We thought we found it. Then the light came back on again but is very intermittent, probably off more than it is on. I'm really puzzled.
I really think we can drive it to a dealer, but I'm not ready to trust it to an extended trip. Is this engine subject to sludge problems?
Old Jan 22, 2007 | 01:01 AM
cstarky15's Avatar
well if it is more off then on then you might be able to make it to your dealer. IS the dealer close by or is it like a 25 mile trip? all engines have sludge problems
Old Jan 22, 2007 | 09:19 AM
david9999's Avatar
Be unusual to sludge at so low a mileage, but it could happen. I wouldn't fool around as there is no quicker way to trash an engine than low oil pressure.
Old Jan 22, 2007 | 03:18 PM
WoodyS's Avatar
Thinking about this problem in bed last night, the thought occurred to me that possibly the oil filter is clogged and not allowing full flow/pressure to reach the pressure switch (and obviously the rest of the engine). Does anyone know whether the pressure switch is upstream or downstream of the filter from the oil pump? A new filter (with oil change) would certainly be a simple solution.
Old Jun 29, 2007 | 06:36 PM
RZA's Avatar
RZA
i just bought an audi a4 2002 3.0i yesterday.it has 171.000 km and it has 30.000km oil.what type of oil should i use to complete the oil if the oil pressure sensor appears on the screen?please tell me the exact oil type.thankyou
RZA's Avatar
RZA
Old Jun 29, 2007 | 06:38 PM
RZA's Avatar
RZA
the low oil sensor appears.sorry.please tell me what type of oil should i use.thankyou.
