MAF READING...PLEASE HELP...
Old Jan 9, 2006 | 07:05 PM
A4_1.8_20v's Avatar
Default MAF READING...PLEASE HELP...
hi everyone,
i just vagged my car and got a MAF reading of 27.78 g/s at idle, anyone know if this is good or bad. also my car does like 10 miles per gallon!!!!
my cars a 97 1.8 20v.
thanx....
Old Jan 9, 2006 | 07:23 PM
onepoint8tee's Avatar
Default RE: MAF READING...PLEASE HELP...
If there is no fault code related to the MAF its probably fine I would assume.
Old Jan 9, 2006 | 07:24 PM
TomRitt's Avatar
if thats the highest it goes to at wot, thats awful, def bad
TomRitt's Avatar
Oh and I have a working sensor without the housing I can sell you for $20 shipped
Old Jan 9, 2006 | 07:45 PM
InsaneHatter's Avatar
ORIGINAL: A4_1.8_20v
hi everyone,
thanx....
Tom, thats at idle ... im thinking its doing ok.
Have you changed you plugs?
Is your tire pressure ok?
Do you have any vaccum leaks?
What gas do you use?
Im trying to think of more MPG issues...
Old Jan 9, 2006 | 07:50 PM
TomRitt's Avatar
wow im reatarded, log it at wot
Old Jan 9, 2006 | 07:52 PM
ORIGINAL: TomRitt
what should the WOT reading be?
Old Jan 9, 2006 | 07:59 PM
TomRitt's Avatar
I believe stock is around 120? an it gets maxed out at ~186
Old Jan 9, 2006 | 08:01 PM
Thats housing limited is it not?
Old Jan 9, 2006 | 08:38 PM
TomRitt's Avatar
kinda.The most the sensor can read is 186, but if u put the sensor in a hosuing with a bigger surface area, the air velocity is going to be less, hence once its maxed out in the stock housing, u switch to a bigger housing, and scale injectors equivalently
