MAP LIGHTS
Old Aug 8, 2005 | 10:48 PM
konvex's Avatar
Default MAP LIGHTS
Both my map lights don't work on my 98 1.8T. So i tried to change the lights and i took the plastic casing off but i don't see where the bubls are supposed to go for the map lights. I only see the bulb for the dome light...I purchased the bulbs already but i'm sitting here scratching my head trying to figure out where the other bulbs go...can someone help me with this simple problem please...(you would think this was rocket science)
Old Aug 8, 2005 | 10:55 PM
Jestnomen's Avatar
6th Gear
Default RE: MAP LIGHTS
does this help?
http://forums.audiworld.com/a4/msgs/536302.phtml
Old Aug 8, 2005 | 11:16 PM
konvex's Avatar
This helped but i'm wondering do i have to take the whole unit for the map light bulbs to be accessible?
Old Aug 9, 2005 | 03:05 AM
konvex's Avatar
Ok I figured everything out...Thanx anyway...The Sylvania site that issues the bulb numbers for specific cars was not correct, therefor I purchased the wrong bulbs...There were no bulbs in there when i bought the car so i was confused as hell....
Old Oct 6, 2005 | 12:12 AM
jrborgonia's Avatar
How did you remove the plastic housing? My map light is also busted, I need to change it but I am afraid that I will break the plastic lens/housing if I don't pull it from the correct spots.
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
