MAP sensor....i DO have one
i found out i do have a map sensor....if the map is located inside the stock airbox in a "tubular" structure....then i DO have one....if this is the map....What can i do performance wise with it.
and sorry for asking the same questions....but i found out i do have one....if its connected to a "boot" on the top outside of the airbox with one wire coming out of it....
ORIGINAL: ThePaintballGuy
No, thats your MAF sensor. The MAP sensor, which you don't have, is locatedON the SMIC (Side Mount Intercooler)
Josh
Josh
Give it up man, for the 10000000000000000000000000000000000000000X, you have to get a chip
Why dont you want to trust that we know what we are talking about? This is the 3rd time now weve gone over this. You already knew where the map sensor would be located if you did have one, because we told you in your other thread(s). I assume you joined this site to learn about your car. Have some respect and faith in the knowlegable members who try to help you. If you keep this **** up, youre going to eventually just be ignored.
The best way to learn about your car is to SEARCH! And read all the stickies at the top of the A4 forum page. Thats what they are there for.
Josh
Josh
^sort of sounds bad. There may had been a better way for me to word that.... But, you get the point.
ORIGINAL: cincyTT
Im jsut making this **** up as i go along
ORIGINAL: onepoint8tee
Have some respect and faith in the knowlegable members who try to help you. .
Josh
