mbc
Old Jul 16, 2006 | 03:00 PM
tatman9999's Avatar
Default mbc
I have a 99 audi a4 1.8 tip.I boost 10 in frist gear 12 in second gear. and 15 3 and 4th.I put a mbc between the n75h and the wastgate it will only hold 10-11 all gears dosent matter if i turn the noob.It is a 2 prong turbo xs. I do have the n75 still hooked up.I even hooked the mbc up between both turbo hoses it was holding 12.what am i doing wrong? it has a apr chip.
Old Jul 16, 2006 | 04:52 PM
onepoint8tee's Avatar
Default RE: mbc
What are you using a mbc for if you just have a chip?
Old Jul 16, 2006 | 05:16 PM
tatman9999's Avatar
Default RE: mbc
it wont boost over 12 psi in 2 nd and 15 in 3 and 4 th .i have the race n75h valve .and i did a leak test with pressor.I see others boosting 18-20 .i have a tip chip.
Old Jul 16, 2006 | 05:38 PM
Default RE: mbc
ORIGINAL: tatman9999
very strange why you are limited to such low psi... check for fault codes and go back to the stock n75 to see what happens with it. Do a TBA as well if you are DBW... I think some late model 99's are DBW, not positive on that though.
Old Jul 16, 2006 | 07:07 PM
tatman9999's Avatar
Default RE: mbc
what is dbw. and tba? i switched back to the stock n75 it is the same the stock n75c. I put a audi tt n75h .never spikes over 15. and holds 12-14 most of the time and tappers off at3800rpm. Im think of upgrading to a awe ko4 with gica softwear
Old Jul 16, 2006 | 07:39 PM
StepUpProductions's Avatar
Default RE: mbc
DBW= drive by wire... no direct physical linkage between pedal and throttle body
TBA= throttle body adjustment
Old Jul 16, 2006 | 08:41 PM
tatman9999's Avatar
Default RE: mbc
it is not drive by wire .How do you do a tba?what shoud my car be boosting in all gears with my upgrades?If
Old Jul 16, 2006 | 09:02 PM
a4orce1's Avatar
Default RE: mbc
I dont know why you guys mess with the n75 or add mbc. APR doesnt do it, GIAC doesnt do it, REVO doesnt do it, they don't tell you to. Leave those things the way they are, it will only be problems
Old Jul 16, 2006 | 09:58 PM
Default RE: mbc
ORIGINAL: a4orce1
ECS (apr dealer) sells them and lists what engines it is compatible with fool! The giac dealer i got chipped at sells them and the owner has a J valve in his a4. Some people have problems with them, but it is on a case by case basis. I agree that a mbc isnt really needed for anything other than a BT setup.
Old Jul 17, 2006 | 12:03 AM
tatman9999's Avatar
Default RE: mbc
what is the diffrence between the n75h and the n75j valve?i have a audi tt from audi n75h.is there a diffrnce between them or the ecs one?
