MBC need some help..
Old Nov 29, 2006 | 05:14 PM
JohnnyBravoA4's Avatar
Default RE: MBC need some help..
sounds like you have a boost leak, i had a ko4 i would spike as high as 25 but with the mbc i held it back to 20, and I would hold around 16psi on a real cold day 18, with my passat i would spike to 18-20 and hold 12-15 with my apr chip, if you fall below 8 there is a problem..
Old Nov 29, 2006 | 05:23 PM
new2me's Avatar
JohnyyB what should i set my boost at?
Old Nov 29, 2006 | 05:27 PM
well that depends on what you want, what I did was i just kept messing with it till I liked where the boost was, for the ko3 keep spikes around or under 20 so set it just under 20 and you should be fine, you should get a holding gain of 1-3 psi with the mbc
Old Nov 29, 2006 | 05:41 PM
new2me's Avatar
That's what i was thinking i just wanted to make sure.
Old Nov 29, 2006 | 05:43 PM
its an MBC so its touch and go, its a cheep fix to a bad problem..
Old Nov 29, 2006 | 06:20 PM
AudiTurbo's Avatar
i dont fall below 8....i heard that this might be becuase mine is a 98, and the computer is set up different.
Old Nov 29, 2006 | 06:22 PM
i thought you said you fall to 8 or so.. either way thats to low, my freinds 98 with a giac chip never fell below 13 or so, the chip controls the boost
ORIGINAL: AudiTurbo
did your boost ever fall off? Mine will go to about 17 then by redline im back down to 8 or so...third gear hold the longest(holds at least 15 all the way to 5k).
Old Nov 29, 2006 | 06:27 PM
  #18
AudiTurbo's Avatar
what should i do then? i have checked for leaks everywhere, and nothing...
Old Nov 29, 2006 | 06:31 PM
  #19
did you do a presure test there are a few DIY test for boost leaks.. check you n75 valve might not be pluged, and check to make sure your have you DV installed properly it might be backwards, or if its a stock DV buy a new one..
Old Nov 29, 2006 | 06:32 PM
  #20
AudiTurbo's Avatar
I have forge007 and i have it just like stock(people told me it doesnt matter)
