MBC on stock ecu.
Old Aug 29, 2007 | 01:41 AM
Stuntman's Avatar
Default MBC on stock ecu.
98 A4 Quattro 5spd. AEB.
I have done alot of research about the MBCs on stock motors/ecus. Understanding a chip has 3 functions.
Raise boost, fuel curv, Bump timing. Im going to gradually bump my boost up using a mbc. Im using a buddys Wide band o2 and software. And a real time VAG diag screen. My 3 funtctions of the chip will be. MBC to raise boost (safly). Wide band for a/f monitor. Heres the thing tho. Alot of people have been stumped by timing. I have drivin the car with a real time VAG. The ECU actuily changes the timing in real time. Its not set at a solid degree. I have seen it bump from 11 deg to 17 deg tdc under load. As for fuel. The ECU is set to run 8psi. I will be leaning out a little ( depending on boost.). I have seen Under load with a/c on reaching a boost lvl of 10psi. with an A/F ratio of 12.4. That tells me I should at least safly handel 10psi.I will be bumping 1psi pre cycle test. Givin time for ECU to adjust. My goal is to SAFLY reach 12-13psi.
Pics and write up coming soon.
Old Aug 29, 2007 | 02:08 AM
qUaTtRoA4's Avatar
Default RE: MBC on stock ecu.
from what i understand you can use an ebc and run 14psi without any spiking issues (or any other mods), but anything over 14 and you're gonna end up in limp mode
why wouldn't you just get a chip tho?
well, anyways, good luck!
Old Aug 29, 2007 | 03:10 AM
Jeff's Avatar
Zombie Defense Force
i ran 22psi on my turbo and bad things happened lol
Old Aug 29, 2007 | 07:17 AM
discontained's Avatar
i ran 16 psi, but often went into soft limp mode due to a boost spike.
Old Aug 29, 2007 | 09:08 AM
Lazer Viking's Avatar
limp mode dosent exist on dbc cars
Old Aug 29, 2007 | 11:18 AM
Stuntman's Avatar
+1 lazer. AEB dbc. No limp. I dont think ill risk 16psi unless I have the fuel for it. (Will know shortly).
To be honest, I would rather get a chip. But funds/timing dont permit. Like I sayd in earlyer posts. Wife 3 mos pregnant. So im trying to get all my tuning jollys out for now. At least my A4 is a 4 door! WooT!
Old Aug 29, 2007 | 11:22 AM
onepoint8tee's Avatar
ORIGINAL: Stuntman
Congrats on the wife being preggers!
Keep an eye on the classifieds here and on oither Audi forum sites, there are always chipped ECU's for sale for AEB/dbc engines.
Old Aug 29, 2007 | 02:03 PM
qUaTtRoA4's Avatar
+1....sounds like someone took their girl to arbys!
Old Aug 29, 2007 | 02:14 PM
wood_e's Avatar
5 for 5.95 - can't beat that
dc878mmm
Nov 2, 2013 02:02 PM
luxuryimports1
Oct 7, 2009 04:40 PM
Ringin'It
Feb 3, 2009 02:38 PM
A4 the Quattro
Nov 10, 2007 10:20 PM
