Minor Problems with my 1996 A4 2.8
Old Jan 25, 2008 | 01:39 AM
audiboyy's Avatar
Default Minor Problems with my 1996 A4 2.8
i have been driving my audi for about 2 weeks now i recently got it onto the road and it has been having some minor problems. The ABS light is on and so is the brake light. i had done the brakes my self and there was so sensor removed in the process anyware i was wondering how can i turn them off because souldnt they both be off? the brake light sould go on when the pads have been depleted right? and also my check enginge light has recently gone off and it now constantly lit up. Could it be that my stub mount is shot and the engine has moved and cause it to set something off. And the heating screen has been shutting off along with the whole intire heat not for long it just flashes and it shuts off and goes right back on sometimes fast enough for the screen to just blink and the fans keep running. If someone could give me some advice it would be really helpfuf
Old Jan 25, 2008 | 02:16 AM
audiboyy's Avatar
Default RE: Minor Problems with my 1996 A4 2.8
Also My front passenger window doesnt work as well the sun roof if any of you guys can tell me like which parts would go first so i can start buying parts for my car ive always wanted to own a audi and i finally do i wanna get this car in good shape please help guys
Old Jan 25, 2008 | 02:28 AM
Jeff's Avatar
Zombie Defense Force
go to auto zone and get your codes pulled. it will help us out when telling you wnat needs to be replaced. check your fuses to see if the heating one is loose. sorry i cant help you with the window problem
Old Jan 25, 2008 | 10:11 AM
01AudiA4's Avatar
Yes the window is most likely a fuse. And when you said you took out the sensor. Dumb reply but did you plug it back in?
NHolzschuh
Apr 30, 2011 08:41 PM
weaselciuy
Nov 13, 2008 06:15 AM
kevins
Feb 13, 2007 04:31 PM
Trey25
Nov 15, 2006 04:54 PM
98 A4 Turbo
Nov 9, 2005 01:23 AM
