Misfire? HELP PLEASE!
Old May 22, 2007 | 07:35 PM
Ericp501's Avatar
Default Misfire? HELP PLEASE!
I was driving and I lost most power (still driveable) but very poor.. it pretty much sounds like a helicopter from my exhaust.. I called audi and he said to replace the ignition coils since my CEL was flashing. Well first I replaced the spark plugs, I then ran a tester from the ignition coils to the plugs, I'm getting nothing from cyl 2. so I tried switching that ignition coil with one that was working and still nothing. so I don't think its the ignition coil.. what could it be????
Any help would be great guys I just started school and I'm supposed to drive to baltimore this weekend.. This couldn't have happend at a worst time!
Old May 22, 2007 | 08:01 PM
auditech79's Avatar
Default RE: Misfire? HELP PLEASE!
ICM or power output stage that sits on the airbox, has one connector on each side.
Old May 22, 2007 | 08:20 PM
Ericp501's Avatar
that simple? thanks!
Old May 22, 2007 | 08:23 PM
auditech79's Avatar
That simple.
Old May 22, 2007 | 10:44 PM
acetrebo's Avatar
2nd that^^^
Very common problem, especially in cyclinder 2 for some reason.
Its a $100-$150 part, very easy to swap out.
Old Jun 1, 2007 | 01:15 PM
Ericp501's Avatar
I think that was it.. I got a $35 aftermarket part and it hooked right up.. now the check engine light is still on and when i first turn on the car the rpms bounce like 3 times then set.. but it stopped flashing and seems to drive fine.. i was told the light will go off by itself in 150 miles tops.. any feed back?
Old Jun 1, 2007 | 01:21 PM
techbod's Avatar
very possible its called cycle and after you have driven it a few time the ECU will set to your driving conditions
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
