my 02 a4 needs help, possible immobilizer problem
Old Jun 25, 2006 | 06:13 PM
drageron's Avatar
Default got it out
i removed the plug from the airbag ecu and tried to start it but kinda getting the same thing. maybe i need to make sure that i am getting pwer to my injectors but i dont know how, i know fuel is building in the alluminum rod just above the furl injectors because i can release that fuel pressure but i bet that i am not getting the injectors to squirt furl into the cylinders. do i run a new scan and see whats up cause i dont have the equip to test if the fuel injectors have power, i dont hink maybe its easier than i thought
Old Jun 25, 2006 | 07:50 PM
drageron's Avatar
Default got new info, srry if i am being annoying
i pulled some new codes and got some airbag fault DTCs
would the airbag control module be the culpret of my fuel system shutdown?
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 8E0 820 043 G
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
4 Faults Found:
01494 - Bulb for Parking Lamps: Left (M1)
57-00 - Electric Circuit Failure
01498 - Bulb for Parking Lamps: Right (M3)
01496 - Bulb for Fog-Lamps: Left (L22)
01500 - Bulb for Fog-Lamps: Right (L23)
Address 15: Airbags
Controller: 8E0 959 655 A
Component: Airbag 8.4E 5000
Coding: 0010607
Shop #: WSC 63351
2 Faults Found:
00588 - Airbag Igniter: Driver Side (N95)
001 - Upper Limit Exceeded
00589 - Airbag Igniter 1: Passenger Side (N131)
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 03200
Shop #: WSC 01312
WAULC68E22A269246 AUZ6Z0B0053942
2 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01304 - Radio
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
81-00 - Open
Address 46: Central Conv.
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0619
Coding: 11788
Shop #: WSC 63351
2 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
Address 56: Radio
Controller: 8E0 035 195 A
Note: Excessive Comm Errors
End --------------------------------------------------------------------------------------------------
Old Jun 25, 2006 | 08:43 PM
drageron's Avatar
Default RE: got new info, srry if i am being annoying
would this thing work to erase the front and side airbag deployment codes plus the stored crash data so the car gets back to normal?
without the bags for now of course
http://cgi.ebay.com/Audi-VW-Airbag-r...QQcmdZViewItem
Old Jun 26, 2006 | 03:33 PM
Bohleized's Avatar
Hello
I have a similar problem just bought a 1997 A4 as is condition (needs some work). The car had a problem with the ignition switch would not return. Replaced switch, had to disconnect the battery to do so. Reassembled steering wheel, air bag, dash parts connected battery and ----------- NOTHING. When I try to start it the dash lights come on I hear relays making under the dash but no fuel pump, no starter. Next step I was going to check the switch on clutch pedal?
Your Thoughts
Thanks
Bill
zepher
Jul 1, 2012 10:44 AM
Audistreetracer
May 20, 2012 03:46 PM
timbo108
Jan 7, 2012 02:51 PM
earleyksig
Apr 14, 2009 11:28 AM
RussTT
Dec 6, 2005 04:33 PM
