My steering wheel tightens up...I need help..
Old May 21, 2006 | 07:58 PM
AteUrV8's Avatar
Default My steering wheel tightens up...I need help..
so when Im going under 15mph and try to turn my wheel hard in one direction it seems as if it tightens up and wont allow me to turn it smoothly, it almost seems like there is no fluid somewhere maybe...but ive almost hit a couple things because of this... like trying to turn into a tight parking space and then i cant turn my wheel fast enough so i gotta hit my brakes..
Old May 21, 2006 | 09:34 PM
BadLuckAudi's Avatar
Default RE: My steering wheel tightens up...I need help..
have you checked the ps fluid??
Old May 21, 2006 | 09:47 PM
tip5's Avatar
12v's are notorious for having ps steering problems that your having its actually because of the lack of valves in your motor and the lag and low end hp that causes this. Its the spinning masses through your belts and pulleys that throw your ps fluid at a low level. I suggest finding something else to drive maybe your dsm. Sorry bro.
Old May 21, 2006 | 10:27 PM
A4 the Quattro's Avatar
ORIGINAL: tip5
[sm=laughat.gif] [sm=lol.gif]
ya check your fluid level.. if not this.. your pump may be on its way out.
Old May 22, 2006 | 01:30 AM
Trey25's Avatar
hahaha its like Tip5 was technically and subtley saying your car is slow lol. Sorry dude, you already know this but its mostly likely your pump. I don't know about Audis but on humvees the same symptoms occur when its the pump, plus an annoying "gurgling" sound.
Old May 22, 2006 | 05:40 PM
AteUrV8's Avatar
ORIGINAL: tip5
thats messed up, lol.. but its all good, sounds like the pump, maybe the ps fluid is low, sounds like an easy fix either way
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
bosullivan
May 26, 2007 10:42 PM
hazz37
Nov 1, 2006 01:39 AM
