N75J Install...Help!!!
Old Jun 14, 2007 | 07:41 PM
kpatz's Avatar
Default RE: N75J Install...Help!!!
ORIGINAL: AudiTurbo
i see that one of the smaller ones is bigger then the other..which ones goes to the wastegate, and which one goes to the turbo...
I don't think it matters which stem goes where, as long as the long one goes into the TIP. The two short stems are always open to each other (turbo to wastegate always flows). When the N75 is opened by the ECU, the long stem opens to the TIP, causing the wastegate pressure to get purged into the intake, increasing boost.
Old Jun 14, 2007 | 08:21 PM
AudiTurbo's Avatar
Oh...ok...Some say you can't get themmessed up, but other say you can.
Old Jun 15, 2007 | 05:45 PM
Aznpulse's Avatar
Member
I always thought that the J valve is installed in reversed. The H valve is installed like the OEM. The J valve is a little Mild compared to the H. It may change depending on setup.
Old Jun 15, 2007 | 07:33 PM
AudiTurbo's Avatar
Yeah it just seems that the plug faces the turbo now, and not the front of the car...
themysteryman83
Feb 7, 2008 02:00 PM
crd945
Aug 1, 2007 12:44 AM
crd945
Apr 2, 2007 04:27 PM
TeeterTawter
Nov 15, 2006 02:54 AM
germancarmaniac
Jun 14, 2005 01:16 PM
