Need help with a few DTCs
Old Jul 28, 2005 | 10:51 PM
bvass's Avatar
Default Need help with a few DTCs
Hi all,
so I looked around for a while and I couldn't find anything to help explain the trouble codes I get. Below is the output I goy from VAG-COM. I'm concerned with the codes under the "Engine" and "ABS" sections.
I have no idea what is wrong with my ABS. Any help will be appreciated.
Where is this boost sensor located?
VAG-COM Version: Release 504.1-D
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07201
Shop #: WSC 06335
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
01200 - ABS Valves Supply Voltage
35-00 - -
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00140
Shop #: WSC 06335
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 C
Component: B5-KOMBIINSTR. VDO D11
Coding: 02244
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06335
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06335
PacificA4
Jun 7, 2012 05:30 PM
v8ramair
B7 Models
May 14, 2011 03:49 PM
gio gio
Jan 2, 2008 03:50 PM
