need help with a sub
Problem: I have two rear deck speakers that are 4ohm.. so i bought an amp to power them. But they kinda give cruddy bass (they are infiniti kappas.. so its not the speakers... and the amp is alpine... trust me i know all the numbers and everything.. its allllllll good)
My Idea: I wanted to buy a bigger amp (1200w) that is 4 channel. And then buy a 2x10' sub by Kicker (max 1000w) and bridge that to the 3rd and 4th channel of the 4th channel.
For the rockford fosgate 1200w 4 channel amp.. at 4x4ohms it runs 50w per channel..... but how many will it run at 3x4ohms (considering 1 is bridged).
Here are the links
Kicker Sub
Rockford Amp
Is this a good idea to do.. because I can return that first amp i bought.. and my idea was to set the rear decks to run on hi freq, and the subs to run at either full or low... depending on the quality i'd get.
I was researching that this is the cheapest way for me to get great bass and not have to really replace much by buying new equipment.
Thanks.
Here are the links
Kicker Sub
Rockford Amp
Thanks.
