Need some help
Old May 16, 2006 | 08:20 PM
kaklexicon's Avatar
Default Need some help
hey, i need some help/input. lately my car's been really jerky whenever it has boost. If it's boosting at around 5 psi i can feel it jerking, but if i'm at 10-15 psi, it's not that jerky but not as fas as it should be... i just had a big boost leak fixed about 2 weeks ago. I'm wondering if i have another one already? Because it doesn't jerk at all when the turbo doesn't kick in.
Old May 16, 2006 | 08:33 PM
Beer Mod's Avatar
Default RE: Need some help
Turbo surge due to over boost? Bad clutch?
Old May 16, 2006 | 08:37 PM
kaklexicon's Avatar
what would cause it to overboost?
Old May 16, 2006 | 08:42 PM
Beer Mod's Avatar
1) cracks in the line between the wastegate and the turbo.
2) after market BC or N75valve.
3) 15psi could be over boosting a old KO3.
Old May 16, 2006 | 10:48 PM
kaklexicon's Avatar
Oh I see, thanks for the info Beer. That line between the wastegate and the turbo... do you mean that tiny little hose that goes from the n75 valve to the FPR? I took my ecs-tuning n75k valve off and put the stock one back on yesterday. That helped a tiny bit but it still does it... this 'surging' that is.
If it was the clutch slipping then I would feel the jerkiness all the time right? Since it only does it when there is boost I kinda ruled out the clutch. Is that a safe assumption?
Old May 17, 2006 | 12:44 AM
BadLuckAudi's Avatar
its probably a vac leak or a bad dv man, check your dv see if its workin properly
Old May 17, 2006 | 11:49 AM
north5995's Avatar
If you search under my name I had/have the same thing. Mine surges between 0-5 psi. I think it has something to do with using the green spring in the Forge007. When I used the other springs I didn't have the surging, but I also wasn't boosting nearly as high. With the green spring the car can hit 21psi, with the blue/red it only hit 15/12 psi @ wot.
I think its just something you have to learn how to avoid. Over the past month I have learned how to avoid it, mostly by driving faster .
Old May 17, 2006 | 12:13 PM
kaklexicon's Avatar
badluck: My Bailey DV is only a few months old. They're supposed to be pretty strong right? I hope my DV isn't busted already.. How do I test it?
north: so your car surges too.. but you just sorta deal with it? Maybe I'm picky but I just think it's really annoying. With the Bailey DV I boost around 16. 21 psi, thats alot of boost! and you have a stock k03 right?
Old May 17, 2006 | 01:11 PM
north5995's Avatar
Yeah K03, GIAC chip, N75H, swisscheezed the airbox. Cleaned my TB and MAF - actually helped.
Yeah I just sort of deal with it until I figure out why its doing it. I was doing a lot of reading on AZ about the surging and with my green spring in the forge it seems normal. So really I don't know what to do about it. When I do my timing belt I am going to take my whole front end off and check everything out. See if I can pin point it, but it seems like a lot of poeple have the same issue.
Old May 17, 2006 | 01:30 PM
Russ03A4's Avatar
I had the exact same thing happen after I had Renn Art put a DV and REVO software in. I thought it might be the DV or a Vac leak too.
I brought it back to Renn Art and they cleared codes in my onboard computer and the problem went away.
Can't explain it but it worked!?!
