AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Newb: "SAFE" displays on Radio (https://www.audiforums.com/forum/audi-a4-8/newb-%22safe%22-displays-radio-71977/)
jake123 Aug 11, 2007 10:29 PM
Before you start to yell, I searched. I came up with the battery had recently been replaced, and needed a program code before using the radio, but myne is different (I havent had the battery replaced, and there are less than 5k miles on the car).
When I turn on my A4, it says SAFE on the radio and on the screen located on the dash. I read in the manual that this will happen if I am using the wrong key. I am using the correct key which starts the car fine. If I turn on the car, it will say SAFE, if I turn off the Radio, then I turn it back on... It will work. Is there a solution that will fix this?
Thanks
genovese45 Aug 11, 2007 11:14 PM
RE: Newb: "SAFE" displays on Radio
go in your manual itshould have a codeand it will tell you exactly what to do and if you dont have the code you should call your local audi dealership..
jake123 Aug 11, 2007 11:29 PM
I couldn't find the code. I am just worried about a Dension ipod dock I have built into the car, they may blame it on that and void the headunits warrenty.
CLX Aug 12, 2007 07:55 AM
It sounds like you have a loose connection to the radio's power somewhere, and you might want that checked out by a dealership. They can also tell you the code while they have the radio pulled out.
