No car
Old Jul 25, 2005 | 09:40 PM
Dave666's Avatar
Default No car
So i noticed a leak a few days ago .. and it started getting worse.
Then yesterday it misfired when i started it up.
Then this morning on my way down to the dealership , the CEL was flashing and it was misfiring the whole way down.
They pulled some codes but there were too many for my to remember , lol .
they arent doing any work on it till Friday .. god...
I will post the codes when I get my car back.
I have lost my freedom
Old Jul 25, 2005 | 09:48 PM
Jestnomen's Avatar
6th Gear
Default RE: No car
Yikes, sorry to hear that man. Sounds like a coilpack problem?
Old Jul 25, 2005 | 09:50 PM
Dave666's Avatar
Default RE: No car
Yup thats what must be causing the misfires. Ive had Coil problems in the past..
But the leaking valve was really bad .. No boost
Old Jul 25, 2005 | 09:58 PM
Prothymos's Avatar
Default RE: No car
wow that sucks man, sorry to hear it
n00b question, what does the coilpack do?
Old Jul 25, 2005 | 10:02 PM
TomRitt's Avatar
Default RE: No car
Ahh i feel you pain, i;ve had no car for a month on wed, and its almost time for some new shoes on the huffy[:@]
Old Jul 25, 2005 | 10:09 PM
PandaXpress's Avatar
Default RE: No car
im sorry to hear that ife sucks wit out a car
Old Jul 25, 2005 | 10:42 PM
GeilKyle2's Avatar
Default RE: No car
what does a coil pack do? A coil is a form of a smiple tranformer in electrical terms. A coil contains 2 sets of electrical windings a primary and secondary. When voltage is applied to the primary windings(battery voltage) and then quickly removed it induces a steped up much stronger voltage into the seondary windings, enough to jump a gap across your spark plug. So basically it creates your engines spark. Most cars will have a single coil(with a distributor) or 1 for 2 cyclinders(waste spark system). But on your higher $ cars (audi) there is 1 for each spark plug (coil per plug system). Hows that Prothymos
Old Jul 25, 2005 | 10:55 PM
Prothymos's Avatar
Default RE: No car
ha, thanks, that makes sense now...
Old Jul 26, 2005 | 02:03 AM
TomRitt's Avatar
Default RE: No car
And when you go standalone with a waste spark system you need to ditch the stock coilpack, because they would need to recharge 4 times as fast which isnt possible. (Thought I would throw that in cause i learned it this week )
Old Jul 26, 2005 | 02:20 AM
lidonnit's Avatar
Default RE: No car
What coil packs can you use instead Tom?
