Now the luck is going down hill
Old Dec 21, 2007 | 12:49 PM
  #21
auditech79's Avatar
Default RE: Now the luck is going down hill
ORIGINAL: a4owner
When you push in the clutch the noise goes away. Does this add up to it being the input shaft bearing?
The only difference between the throwout bearing noise and the pilot bearing noise (inside flywheel) would be how far you have to push the pedal to stop the noise. If you only have to push the clutch slightly to half way down to stop it, its the throw out bearing. If you have to push the clutch pedal to the floor to stop the noise its the pilot bearing.
Either way when you do the clutch you should replace all of these bearings anyway.
Old Dec 21, 2007 | 12:57 PM
  #22
a4owner's Avatar
So is there an input shaft bearing that could be bad? How does the mechanic come up with it. I have to push the pedal all the way down for it to stop. So this would be theclutch? Or is there anyway it could be the trans? Trans shifts great with no problems thats why I have a problem with the tranny being the problem lol
oldmots
Aug 8, 2011 08:13 AM
richpg
Feb 22, 2011 06:10 PM
never_enough
Jun 15, 2009 11:20 AM
