OEM Turbo Question?
Old Feb 15, 2007 | 03:12 PM
eurwaudi1.8's Avatar
Default OEM Turbo Question?
I just bought a 1998 A4 1.8 quatro. The turbo is blown got a good deal on the car otherwise mint pearl white/black leather. I was wondering if a stock turbo from a 1998 passat 1.8 woud fit on my car (I want to feel the stock power before I upgrade).
Old Feb 15, 2007 | 03:23 PM
Lazer Viking's Avatar
Default RE: OEM Turbo Question?
yes... but if your replacing the turbo you might as well get a k04
and run it on stock tuning to feel stock power... then when you know you want more just upgrade software
Old Feb 15, 2007 | 03:27 PM
So the Ko4 will be the same hp as ko3 with stock tuning?
Old Feb 15, 2007 | 03:32 PM
MissionCtrl's Avatar
you'll get slightly better power with the ko4. but then once you add a chip there will be noticable gains.
essentially, its a very tiny bit larger then the k03 probably nothing noticible
Old Feb 15, 2007 | 03:37 PM
smokeU's Avatar
how do you know the turbo is blown?
Old Feb 15, 2007 | 04:16 PM
i2onnel's Avatar
Ya, how can you tell when your turbo is blown?
Old Feb 15, 2007 | 04:24 PM
A4nicator's Avatar
oil leak, bad seals, no boost, horrible fuel consumption??????
Old Feb 15, 2007 | 04:33 PM
Oh its blown bigtime the shaft broke due to a feed line blockage. I went to the guys house to check the car out befor i bought it he had already removed the turbo. There were no pieces missing from the turbo veins but I did a compression check just to be safe and all 4 were good so i bought the car.
Old Feb 15, 2007 | 04:40 PM
akielb's Avatar
As I was reading down I was just going to say get it rebuilt but that last part kinda sounds like you wouldn't want to
Check out G-popshop.com - they offer very good prices and if you want to upgrade to a k04 they change out the stock internals on a k03 for an extra $100 - stock your looking at 150hp - with this turbo and new software - $600 sometime in the future - you can get 235hp
just in case you don't know - K04 is a stock turbo in the Rs4 so it is audi proven and is the exact same external dimentions as a K03
