oil
i bought a audi the other week it is the a4 quatrro with 2.8 and 5 speed i was going thought the service manul and seen that it was asking oil change every 7,500 to 10,000 if this is true what kind of oil is the facory want you to use and if this is not good what kind of oil should i use and i'll stick with the every 3000 miles.
A good synthetic Oil, depending on conditions, paired with a good filter can last 15k. If you're changing oil every 3k you're wasting your time and money.
www.bobistheoilguy.com
^ go there, read...
^ go there, read...
ORIGINAL: wood_e
^ go there, read...
^ go there, read...
Thats why I said depending on conditions. For long trips and when proper procedures are used to heat the oil up to temp then it can last a long time. Good for you if you drive the crap out of youre car. You can still do that and have a nice long OCI as long as you warm the oil up to the proper temp. The added fuel during engine warm up leads to oil breakdown.
That method won't do a whole lot. Engine oil is for lubrication, not cleaning. If you want to clean your engine out try AutoRX. I've used it and it seems to have helped a bit. The oil filters from my clean and rinse phases were nasty.
