Oil leak, someone who knows what they're doin take a look
Old Nov 10, 2006 | 07:36 PM
Dungar46's Avatar
Member
Default Oil leak, someone who knows what they're doin take a look
I've got too oil leaks on my car, one is coming (assuming you were standing at the front of the car looking at the engine, from the upper rear(what looks like a hose), the other is coming out near the oil pan filter and oil cooler. Here's some pics:
Old Nov 10, 2006 | 07:42 PM
Dungar46's Avatar
Member
Default RE: Oil leak, someone who knows what they're doin take a look
And the ones of the oil filter leak:
Old Nov 10, 2006 | 10:06 PM
TDRILL's Avatar
I can't tell where the first pics are from. I always need a bigger picture to show what area to even look in.....although I don't have a turbo either.
Anyway, the pics of the pan. Make sure that the first leak up in the hoses is not directly over where you see oil leaking at the pan. Its possible you have a bad gasket on the pan, but I bet the first leak is dripping down there and making it look like there is a leak there. Whenever you find a section of oil like that, always look up higher. Oil running down the block and then spraying back accross the bottom of the car is very common.
Old Nov 10, 2006 | 10:27 PM
Amze's Avatar
holy christ, that looks bad =( prolly isnt as bad as I make it out to be
Old Nov 11, 2006 | 12:47 AM
ELECTRO's Avatar
I'm new to Audi's but I've worked on a lot of cars I would clean up the oil and check these spots often this will narrow your search dramatically make sure to keep an eye on the oil level in the car as well.
Old Nov 11, 2006 | 01:09 AM
luvin_the_rings's Avatar
yea, keep a GOOD eye on the oil level!
clean off the oil thats all over the place, drive for a day, then see what's not clean anymore...
Old Nov 11, 2006 | 03:25 AM
BadLuckAudi's Avatar
looks kinda like a pan gasket
taylorjwbrown
Jun 21, 2013 11:59 AM
casko
Oct 7, 2012 03:03 PM
Leftcoast74
Aug 14, 2011 06:19 PM
AUDIjp98
Dec 8, 2007 05:40 PM
AWDaholic
Nov 9, 2005 10:58 PM
