ok im thinking about this to get me in the 12's what do you guys think?
Old Mar 10, 2006 | 08:36 AM
audienvy's Avatar
Default ok im thinking about this to get me in the 12's what do you guys think?
ATP GTRS kit with EuroCode/REVO Software, Injectors & 2.5in Test pipe, full exhaust and a big *** fmic. what do you guys think? im trying to hit mid 12's with out doing any internal motor work.
Old Mar 10, 2006 | 08:37 AM
audienvy's Avatar
Default RE: ok im thinking about this to get me in the 12's what do you guys think?
lol or i want to go as fast as i can with stock internals.
Old Mar 10, 2006 | 12:45 PM
quattrosedan's Avatar
WAIT....there is a gt30 series turbo kit coming out.........
Old Mar 10, 2006 | 01:17 PM
InsaneHatter's Avatar
I think the GTRS Kit w/ Revo is actually putting out 12's...
hmmm what year is your car? Im not sure what the b6's engines can handle , but my AEB can handle 400BHP which is like 350WHP...
The GTRS w/ Revo kit will most likely be around the 250-280 WHP range.. I would think it would be in your effiencieny
Old Mar 10, 2006 | 01:28 PM
Dave666's Avatar
Sounds about right .
Go for it
Old Mar 10, 2006 | 03:42 PM
flyinb501's Avatar
ORIGINAL: audienvy
That should get you into the high 12's.
Old Mar 10, 2006 | 03:48 PM
GraffixWB's Avatar
ORIGINAL: flyinb501
ORIGINAL: audienvy
ehh!?! i'M NOT SURE THAT WILL GET YOU INTO 12'S. Maybe with racegas and high boost. the 3071r should get you there.
Old Mar 10, 2006 | 03:58 PM
flyinb501's Avatar
ORIGINAL: GraffixWB
ORIGINAL: flyinb501
ORIGINAL: audienvy
ehh!?! That kit holds the b6 world record at 12.63. So I think you'll be good.
Old Mar 10, 2006 | 06:33 PM
audienvy's Avatar
my car is a 99. what trubo should i get if one day i put some rods and pistons in my motor? gtrs, 3071r or gt30??
its going to be about a year before i go into the motor. unless something brakes.
can any one tell me the up and downs of these turbos? gtrs, 3071r and gt30?? i just want to know when they spool what hp they can push and how much lag they have.
Old Mar 10, 2006 | 06:41 PM
There are many trims (sizes) availabe for those turbos but this is a general rule of thumb:
The bigger the turbo, the longer the spool time, but the more PSI and HP it can handle.
Bigger turbos require less boost to create the same HP levels though, this is becuase the air is cooler/denser.
If you built your motor w/ good rods and pistons.. I would suggest a BT .. 3071R would be a good choice.. or if you want a t3/t04e.
the T3/t04e w/ Standalone can reach about 300WHP on 10/11PSI... and w/ a built lower end could make ALOT more on 15-20PSI
