Oxygen Sensor
Old Apr 20, 2006 | 11:48 PM
707782y's Avatar
Default Oxygen Sensor
When are you suppose to replace the oxygen sensor? I heard that you will get better Gas millege if you replace it, how big is the MPG will improve?
I noticed that the universal type is a lot cheaper than the OEM type, is there any difference between the two? Will it affect the car's performance or life?
Where can you buy it for the cheapest online? and about how much will the auto shop charge to install it for you?
Thanks
__________________
Old Apr 21, 2006 | 12:17 AM
PandaXpress's Avatar
Default RE: Oxygen Sensor
you replace the 02 sensor when it breaks it breaks alot, its a common problem wiht audis liek coil packs[:@][:@]
and there are to 02 sensor
Old Apr 22, 2006 | 01:53 PM
dankhound's Avatar
The univerals types are a cut and splice type deal. Not a good idea on system that operates between 0 and 1 volt. Change out a good sensor with another good sensor will not help milage at all. Just wait untill you get the check engine light for it and then do yourself a favor and replace it with a sensor designed for your car.
drft1
Jul 5, 2010 12:18 PM
spiney
Jul 15, 2009 10:18 AM
j_ripper19
Sep 30, 2008 09:57 PM
brent07
Jan 19, 2007 03:57 PM
david9999
Aug 11, 2005 07:23 PM
