p0411 Secondary Air Injection System
Hey I know there are other posts about this(and they were all very helpful) but I was wondering since the SAIS isnt a super necessary if there was anyway to eliminate it all together and get rid of the CEL. My concern is if another code pops up I wont know its there if its something important. And I certainly dont want to pay the to fix it as its sooo expensive. So I guess my question is, is it possible to just remove the system without getting a CEL? or is there any other way to trick the ECU into thinking everything is on the up and up?
Thanks for you time!
Zack
P.S. I dont think its the pump because Im not getting the jet engine noise like the other people, im thinking its just a vaccuum hose or something but i just want to rid myself of the system all together
Zack
Zack
Zack
the jet noise isnt necessary. first i would check the fuse located in the ecu box. if its blown replace it. it it blows again its a bad pump. if the fuse is not blown then its a vacuum line.
there is ways to get the ecu flashed to void the sai from the ecu. but i do not know who does it or where to get it. if anyone know let me know. i need to void it on my 2.7
I don't know about Audis, but I just replaced the SAI pump and check valve on my 2003 Saab 9-3. Do Audis have a check valve? On the Saab, sometimes just cleaning out the check valve is all that is needed.
You know that the SAI pump is there for emissions purposes, right? If you managed to remove it, I wonder if it would be caught at an emissions inspection.
jafferman
May 6, 2013 06:32 PM
audirpm
Jun 4, 2008 08:48 PM
Texas_A6_4.2
Jan 17, 2007 02:29 PM
