P0420 - Catalyst Code
Old Jul 8, 2013 | 07:28 PM
JoshuaMcbee's Avatar
Default P0420 - Catalyst Code
So I just got a P0420 Code. I've read a lot about this and seen a lot of different prices.
Possible Solutions Some suggested steps for troubleshooting a P0420 error code include: Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required. Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady). Inspect the downstream heated oxygen sensor (HO2S), replace if necessary Replace the catalytic converter Overall probably the biggest mistake vehicles owners make when they have a P0420 code is to simply replace an oxygen sensor (H02S). It is important to do proper diagnosis so you're not wasting money replacing parts unnecessarily. We strongly recommend that if you need to replace the catalytic converter that you replace it with an OEM unit. Second choice would be a high-quality replacement part. There are many stories in our forums where folks replaced the cat with a cheaper aftermarket one only to have the code return shortly thereafter. One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
Read more at: P0420 Error Code: Catalyst System Efficiency Below Threshold (Bank 1)
Copyright © OBD-Codes.com
So my Question is, what is a good oem catalytic converter go for? I don't want to buy a real cheep one just to have my error come back. I also don't want to send $900 on a catalytic converter. (Side Note) I'm over the 80K Mile warranty for the converter.
I was looking at this one http://www.ebay.com/itm/2000-2001-2002-2003-2004-2005-2006-Audi-A4-1-8L-Catalytic-Converter-Direct-Fit-/271047672167?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f1bb34167&vxp=mtr
M3Armand
Mar 12, 2013 04:53 PM
ahsaw
Sep 30, 2011 09:06 AM
shiles831
Sep 12, 2011 01:29 AM
fly200
Mar 20, 2010 04:52 AM
Mike02A4
Sep 29, 2008 05:45 PM
