parking lights and fog lights, need info
i want to know if there is a way to run my parking lights with my fog lights at the same time on my '05 a4, if anyone knows anything about it and could let me know that would be great. Thanks
I'm not sure if this will accomplish exactly what your after... but you can vag-com your car, and switch it to the Canadian specs for lighting... which means fogs are on all by themselves (in addition to the corner lights -- the orange ones in your headlights) at all times...
Until you turn on your headlights... then the fogs turn off... and you can manually turn them back on. Fogs turn off, when you turn on your high beams.
I live in Canada, with a canadian car... I wish I had it how you guys do!
thanks for the info , i thought it was a possibility because a friend of mine has a 05 passat wagon and he is able to run his running lights with his fog lights by removing a fuse
this is for an a6 and at the top it says there is a VAGCOM fix for this
http://www.audizine.com/forum/showth...threadid=36066
a vagcom is a tool for your car that plugs in to that thing under ur steering wheel, it allows you to access the computer.
is the vag com something that can be purchased or can be used at an after market install place? ive got buddies that can get a hold of pretty much anything if needed, i guess im curious where i can get it through
heres teh product. http://www.ross-tech.com/ you can buy it. or if your friends have one ur in luck!!!
nize
Jun 21, 2013 01:16 PM
chesterfan1230
Apr 17, 2011 06:41 PM
