Pic of height difference between 245/30/20 vs 235/45/17
both brand new tires?
inflated same amount?
I'm reaching here, but yeah the calculator I used says a .46" difference, which is still way less than what your pic shows.
weird.
weird.
yeah - .46 for me too. so what is the difference - it looks like more. But depending on how close the camera is the bigger the gap looks. exactly how much difference is there? maybe take a pic with a ruler.
i thought about it and it makes sense the rim is 3 inches taller, and the side wall only 15 mm shorter so the total height of the tire will be about 2.5 inches taller. If i lost you il break it down some more jsut rims the wheel is 3 inches taller. the tires have a side wall of 30 mm for the20 and 45 for 17.the sidewallfor the 17 would have tomake up that 3 inch difference to be equal the calcis wrong, 3 in sidewall is 75 mm about. Thats why there is the gap. if you guys need any more ill do stupid 5th grage math, thus i am smarterthen a 5th grader
something not right there I would fit 245/25/20
http://www.miata.net/garage/tirecalc.html
