Pics of My Audi A4
Check up my New Audi...more pics coming in!!!
Happy 4th of July. [IMG]local://upfiles/20310/9A310338513A43DF8FF04BFF4A01D87D.jpg[/IMG] |
RE: Pics of My Audi A4
I probably shouldn't shoot under the trees...
[IMG]local://upfiles/20310/F051608FDCD749FF8E3E5956665A5CAA.jpg[/IMG] |
My turbo...
[IMG]local://upfiles/20310/B98A5966E00A48BF96633E9E626B0D8A.jpg[/IMG] |
Turbo + Revitalyzer...extra kick for a few hp & torque
[IMG]local://upfiles/20310/6BFDCF3E73ED44E0A30EA98D9EF88D0F.jpg[/IMG] |
Guys please showyour ride and any adjustments you guys have made, tks
hey looks good what is a revitalyer ?
errr is it like a hose?
ORIGINAL: clconversion hey looks good what is a revitalyer ? this is what the manufac. says: 1. Increase the efficiency of your starter motor / Stabilize your idle speed. 2. Increase the torque & gives you a smooth sensation while shifting gears/ maintain and stabilize your engine during high rotational speed. 3. Improve and reduce the knock(pre-ignition) from your engine/ increase your throttle response 4. Improve the efficiency of your fuel combustion so you can save more fuel/ Brighter your headlight. 5. Reduce the static from the audio and highly improve the tone quality. 6. Once you improve the efficiency of your fuel combustion, it reduces the capacity of the exhaust gas emission. So it will level down the pollutants from your car and improve our air quality. 7. Improve the efficiency of the engine and achieve the goal to save fuel by 15%~25% (The result may very, based on the individual driving behavior & the type and year of your vehicle.) 8. Stabilize the idle speed of your engine. 9. Reduce the vibration from the engine and have a better smooth-going performance. 10. To thicker the low-pitched sound (Bass) of your car audio. 11. The LED will show the precise voltage from your car battery. (*Functions will be differing by types.) it looks to me like a capaciator that goes between your battery pos and neg and your alternator or distributor,I've had one on my ex-Subaru and Audi, coz it works very well on my subaru, so I bought another one for Audi, and now I'm looking at the fuel effiency, and later before I chip the car, I'll run dyno to see how much it improve in hp and torque. This is the dyno chart before and after revitalyzer: With the revitalyzer, it has increase 10lb of torque, and 5hp. I was pretty impressed by this, the dip at 5000 is timing getting pulled (3 degrees to be exact from my logs) due to NO AIRFLOW thanks pruven) otherwise is holds 10 whp and torque from spool up to 6000 rpms and would have kept going without timing pulled :wallbash: i gave it a whirl on the way home. I made instant boost in 5th gear roll ons. The throttle response went from stiff throttle cable to a "drive-by-wire feel" my bass no longer hurts my idle or lights dimming, the spool up transition is so smooth and quicker, the car is so quiet idling, and it just feels like a new car all over again and top end feels stronger as it doesnt feel struggling or like its going to break up. Car starts on the first two clicks. I think they are a great product for people who have gotten all the other bolt ons and want a little more oomph. [IMG]local://upfiles/20310/0016DB82552F4A6CA52607BE115509B1.jpg[/IMG] |
hmmmmm .... werid ... never heard of anything like this before ... still a little confused on how a capacitor would do all that for your engine
Not quite sure if I'm buying what they advertise. I'd like to see some proof of the 15-25% increase in MPG and the 2 HP and 9ft lbs of torque that you get for $169....
On a sidenote, Pruven's website is quite cool: http://www.pruvenperformance.com/ . . |
| All times are GMT -4. The time now is 12:16 AM. |
