Please Help..no idea what the problem is...
Old Sep 3, 2009 | 02:50 PM
seahawkfan94's Avatar
Default Please Help..no idea what the problem is...
I've recently been having trouble with my transmission in some way. My gauge clusters are black background with red lighting. The middle cluster under the air temp, mileage left on tank, diagnostics, etc where it says park, reverse, drive etc is in red, with a black background. Basically (from time to time the last week or so) when I start the car (it's a tip) and have it in either auto or tip mode, the entire section of P,R,N,D,S instead of the 1 I'm in at that point is highlighted in red, and the letters are black. Same thing when I'm in tip mode with the 5,4,3,2,1. Instead of the gear I'm in being highlighted in a red square with the number/letter in black, the entire 5 gears are highlighted in the red squares and letters are black.
That's the cosmetic difference; the big thing is the damn car doesn't drive when that happens. If I turn off/on the ignition again it's usually fine. But I had that happen this morning leaving the house, had it in reverse rolling down the driveway (without foot on gas) and when I went into drive, there was no power. Happened again leaving work on lunch 30 min. ago. All was highlighted, and I kept the car in neutral and revved the engine...no power..car just sat there idleing. Anyone know what to do and to what extent the seriousness is?
I've also had trouble off/on the last few weeks with the car starting..had the mass air-flow sensor cleaned cuz a code came up through a friend/mechanic's VERY good diagnostics machine..not something you find at a cheap autoparts store. Won't always turn over right away..especially if there car's sitting for a few hrs.
Any help is greatly appreciated.
Mark
Old Sep 3, 2009 | 03:00 PM
SILVER_B5S4's Avatar
Don't forget to mention that it has been ideling hard for a while now. The last few times I was in it you could clearly feel the vibrations. I'm almost thinking that possible a ecu refresh flash might do the trick. The comp may have gotten corrupted somehow. Hopefully its a system error...that's an easy fix B.
Brautty
Dec 1, 2011 03:48 PM
Terrynt
Mar 16, 2011 04:48 PM
jcorradino
Nov 22, 2010 06:51 PM
CodyR
Feb 1, 2008 07:14 AM
