Please identify this hose on a 2.8
Old Aug 23, 2007 | 10:38 PM
A4 Effort's Avatar
Default Please identify this hose on a 2.8
Could someone please identify this hose on a 2.8? I noticed the other day that this line on my 2.8 is broken right where the red arrow is pointing. The two broken ends arebeing held together by some sort of shrink-tube stuff and it's a pretty weak joint.(that's what he said)
Should i be concerned? Do i need to get this replaced asap? When i pulled the two ends apart, it had a bunch of oil gunk inside of it, so maybe this is some sort of oil breather tube?
Any help would be appreciated. This isn't my engine, but it's the best one i could find that shows the hose clearly.
Old Aug 23, 2007 | 10:49 PM
MrFlippant's Avatar
Default RE: Please identify this hose on a 2.8
I don't know what the hose is, the the supercharger on the engine in the pic you found is gorgeous.
Old Aug 24, 2007 | 12:12 AM
2k S4's Avatar
It's the crankcare breather hose. Yup, you should fix it, as it's now a vacuum leak.
You can also take some heat shrink tubing, & cover the broken part & seal it that way.
Duct tape is also a temp fix.
Old Aug 24, 2007 | 05:04 AM
a88fl1's Avatar
wish i had mine SC'd
Old Aug 24, 2007 | 07:39 AM
A4 Effort's Avatar
Yeah, i wish mine was SC'd too. 2K - thanks for the info. I figured it was some sort of breather tube, but wanted to confirm. I'll just replace it since the shrink-tube idea was tried by either the PO or shop and itdidn't take.
Old Aug 24, 2007 | 04:10 PM
sdsteez's Avatar
sc <3
Old Aug 24, 2007 | 04:37 PM
TDRILL's Avatar
ORIGINAL: A4 Effort
Try it again. I broke mine when I replaced my spark plugs. It is in a very bad position and very brittle. I used shrink tubing and it works great. Duct tape is a very very short term fix. The heat of the engine makes it so that the adhesive stops working and then you just get a huge sticky mess under there. A new breather hose, besides being a pain to install, is pricier than you might think. I believe its around $150. Way too much for a hose that really doesn't do very much. Its not like oil or anything flows through it, just air with tiny amounts of unburned hydrocarbons.
Anyway, here is what worked for me, get fairly large shrink tubing. Cut a piece 3 inches and slide it up the tube and cut a 1 1/2" piece and slide it up the other side. First shrink the 1 1/2" tube with the break in the center of it. Then slide the 3" piece down over the same section and heat it up. Makes the joint almost as stiff as the rest of the hose and should create a pretty decent seal. $2 well spent.
Old Aug 24, 2007 | 09:05 PM
A4 Effort's Avatar
Thanks TD, too late.Bought a newbreather hose today. [:@]$100 bucks. I was actually surprised that the stealership had it in stock.
Ah well, at least i'll have something to do tomorrow and know that it'll befixed right. Not that the shrink-tube wouldn't work, but the thought of itresting against a hot engine only leads me to believe itwill soften up again and tear like it did when they tried to fix it like that the first time.
Besides, it gives me a reason to rip stuff apart and put it back together again!
Old Aug 24, 2007 | 11:56 PM
thekyman's Avatar
i broke mine when i replaced the cam position sensor on my 2.8. is just used electric tape to seal it together, after 5k miles, still sealed good. well at least you fixed it the right way. have fun workin on it!
Old Aug 30, 2007 | 08:18 AM
sineo's Avatar
Was it pretty easy to replace?
While it was broken, do you know if you were getting the P0441 code?
