Possible Wiring/CCU/dashboard/other faults
Old Mar 23, 2012 | 01:36 PM
HCS's Avatar
HCS
Question Possible Wiring/CCU/dashboard/other faults
I have a 2005 A4 avant, 1.8T, which has developed a few faults over a period of time, I can't be sure if they are connected, but I would value any experience anyone else can offer of similar problems.
First, the car managed to lock itself while parked with the engine running (while I got out to open a gate). Don't know if this would have happened again since, I haven't given it the chance.
Second, at about the same time the external temperature sensor started giving some very strange readings (starting most days at -20 to -30 deg C, gradually warming up, don't think it stops when it gets to something sensible). This doesn't seem to have an impact on how the car is running.
Third, most recently when I competely fill the petrol tank the engine temperature gauge varies wildy, and frequently triggers the coolant warning on the dashboard display. Once the fuel tank is less than about 90% full the engine temperature gauge only varies wildly and triggers the coolant warning when I turn left, and below about 80% full the problem does not appear at all. When starting the car from cold, with a full fuel tank, it runs very lumpy, I even stalled it once (a first in the 4 years I have had it).
Thanks for reading all of this, but the garage have already charged me for some repair work which has had no effect and seem intent on the following the "poke and hope" system of maintenance. I would love to know if anyone else has had similar experience before I spend yet more money chasing these faults.
Old Mar 25, 2012 | 02:13 PM
M5S5's Avatar
Tech Certified
It sounds like you might need to get the cluster repaired.
What was the repair work performed?
Old Mar 26, 2012 | 08:28 AM
HCS's Avatar
HCS
Thanks, is the cluster the wiring loom under the passenger seat area?
Dispite everything I had told them, the garage looked at the coolant warning in isolation and repaired some suspect looking wiring joints in the coolant outlet (apparently).
HCS
Mar 23, 2012 01:29 PM
mitchell81
Aug 7, 2011 04:52 PM
mrhurst88
Aug 17, 2006 10:57 PM
Dj Spiel
Aug 31, 2005 03:18 AM
Dj Spiel
Aug 24, 2005 01:49 AM
