potential a4 repairs
Old Apr 10, 2005 | 04:13 PM
pdamer's Avatar
Default potential a4 repairs
what are potential/suggested maintanence issues involved in an a4 when approaching the 50-60K mile range?? thank you
Old Apr 10, 2005 | 04:17 PM
Skibos's Avatar
Default RE: potential a4 repairs
im not up there and not sure but i think timing belt would be coming up ....... might wanna wait for jest or someone to tell u for sure
Old Apr 10, 2005 | 04:24 PM
Jestnomen's Avatar
6th Gear
You should start thinking about changing the timing belt, water pump, etc as skibos said. It doesn't need to be changed until 60-70k miles though.
Old Apr 19, 2005 | 02:16 AM
audicrazy's Avatar
How much do timing belts and water pumps usually go for? I considering a 2000 A4 1.8T with 80K.
Old Apr 19, 2005 | 02:26 AM
BFlan2001's Avatar
ecs tuning sells an "ultimate tb kit" for about 270 bucks iirc....a euro mechanic will charge you between 500-900 dollars....but make sure you (or the mechanic) changes everything...the ecs kit is pretty complete...except you should also change your snub mount while youre in there (it doesn't take any extra time if youre already doing the tb and it costs 13 bucks at www.greedspeed.com, it will reduce driveline shock and save your motor mounts and tranny mounts...
Old Apr 19, 2005 | 08:54 PM
david9999's Avatar
Change the front engine seals at the same time. Only takes 15 more minutes and the seals cost a total of 20 dollars
Tropski
Feb 11, 2013 10:10 AM
1999audia4
Jul 30, 2009 09:35 PM
Schwalbe181
Sep 25, 2008 07:05 PM
DEDMN_TT
Mar 10, 2008 09:29 PM
TetrickA4
Nov 18, 2004 02:10 AM
