Power steering noise when cold????
In the mornings I have a loud humming noisewhich is worse when I turn the steering wheel. When the car is warmed up this disappears. There are some other creaks and groans when I move the wheels at very low speed first thing in the morning aswell.
Does anyone have any ideas???? TDi 1.9 1998 A4 |
RE: Power steering noise when cold????
have you checked your fluid???
its your fluid for sure man. my car did the same thing for a while. go to the store and get some Pentosin 11S i believe. check your fluid level first tho. i'll bet you its low. this also means u might have a leak.
and the leak is usually on the hose that meets the reservoir, or the pressured hose that meets the steel cooler line in front of the A/C condenser.
